The Saab Link Forums - View Single Post - '01 9-5 running poorly,skipping etc
Old 04-12-2013, 08:46 AM   #6
newsaabguy
No problem! looks like we posted at the same time, but thanks for the idea! I am pretty confident I have it narrowed down to the MAF. At least I get real results when I disconnect it. Hopefully a cleaning will help, and if not a replacement. The car was hit right at that corner so it could just be damaged internally. Funny it doesn't send a fault code though. It may just be filthy. I will inspect it good when I remove it for the cleaning. I will update after I clean it and go from there! If needed I can get used saab originals fairly cheap so I will go that route if cleaning doesn't fix it or I find a problem with it.
newsaabguy is offline   Reply With Quote
