The Saab Link Forums - View Single Post - Saab 9-5 window off track?
Old 03-23-2013, 06:49 AM   #8
bergie
bergie's Avatar
yeah stock up on the green rollers and clean & re-grease them so there not noisy and sound like there rolling on sandpaper.. ALSO take a look at the seals around the glass. If the glass panel is not seated right in its rubber sliders seals or not put back in properly you will get water and eventual ice build up if its cold enough. this is mostly what kills your rollers, which is your problem.
bergie is offline   Reply With Quote
