ok. i dont spend a lot of time over here, but i love saabs. anyway, lately ive been putting together some information for a future B204 transaxle 4x4 buggy i have in the works. toughest part i think is going to be the wiring. ive been looking over some wiring harness diagrams, now, these were 9000 diagrams, and ive heard some of the colors are different, but they do the same jobs.
i was wondering if any of you have done a stand alone harness for one of these engines before. currently i have a pinout written down and a modified harness diagram, if anyone could take a look over these and tell me if im missing anything that would be awesome.
Uploaded with
ImageShack.us
pinout:
1 12v HOT AT ALL TIMES
2 APC vALVE
3 FUEL INJECTOR #1
4 FUEL INJECTOR #2
5 FUEL INJECTOR #3
6 FUEL INJECTOR #4
7 NOT USED
8 NOT USED
9 DIC PIN #2
10 DIC PIN #3
11 DIC PIN #4
12 DIC PIN #5
13 REMOVED
14 REMOVED
15 REMOVED
16 NOT USED
17 DIC PIN #8
18 DIC PIN #9
19 NOT USED
20 NOT USED
21 REMOVED
22 MAP SENSOR
23 02 SENSOR
24 GROUND
25 GROUND
26 APC VALVE
27 REMOVED
28 NOT USED
29 NOT USED
30 NOT USED
31 MAIN RELAY
32 REMOVED
33 DATA LINK CONNECTOR
34 REMOVED
35 NOT USED
36 REMOVED
37 REMOVED
38 COOLANT FAN RELAY
39 REMOVED
40 NOT USED
41 O2 SENSOR
42 TPS
43 MAP
44 DIC PIN #7
45 TPS
46 ENGINE TEMP SENSOR
47 GROUND
48 12V HOT AT ALL TIMES
49 ENGINE IDLE SPEED CONTROL VALVE
50 O2 SENSOR
51 NOT USED
52 REMOVED
53 NOT USED
54 REMOVED
55 REMOVED
56 FUEL PUMP RELAY
57 NOT USED
58 RPM SIGNAL OUT
59 REMOVED
60 REMOVED
61 NOT USED
62 SFI TEST SOCKET
63 SFI TEST SOCKET
64 NOT USED
65 SFI TEST SOCKET
66 GROUND
67 GROUND
68 INTAKE AIR TEMP
69 NOT USED
70 NOT USED
