The Saab Link Forums - View Single Post - Oil in radiator fluid
Old 01-25-2013, 02:51 PM   #7
Harvey's Autohaus
Harvey's Autohaus's Avatar
If Atf was found in the coolant & Vice versa then yea, The radiator was bad. If engine oil is found in the coolant, than the oil cooler, located in between the cylinder heads is Leaking internaly into the coolant. or a head gasket issue, but oil in the coolant of any Opel derived 2.5/3.0 is ussually always the oil cooler.
HakbarSAABzzz
Harvey's Autohaus is offline   Reply With Quote
