attempted to jump start after low battery, was unsuccessful, key wouldn't budge to turn, neighbor jiggled something and key turned, but didn't jump start...then it happened again, again now key won't budge...i have wiggled and jiggled steering wheel, no "click" when you put the fob key in ignition, checked 1 & 2 fuse next to drivers door, and also one in engine #2, all fine...car is parked nose in, so towing isn't going to help, bought new battery, installed and still nothing, remote on key works to unlock, won't lock with remote lock, interior lights work when you take key out, have pulled negative off terminal, waited, placed key in without turning hoping to reset, taken key out and re-inputted in several times, turned wheels both ways, my steering column is unlocked, cant budge the gear shifter, cleaned ignition with alcohol, .....next to the positive terminal, i don't have a "relay" i only have coming from the positive terminal, two posts, other than the connector to the positive terminal, one of those posts have nothing and the other gets connected to the fusebox thats right next to the battery, all connections are crystal clean, i have a round black button, which i think is a "reset" button, and have pushed that and pulled that till i'm blue in the face, still nothing.....any suggestions?....i'm a single mom, and can't afford to have it towed, and a saab dealer is about 100+miles away....i can't afford to have it towed to a local shop only to have them guess and replace stuff that doesn't need to be fixed....can anyone help? i'm gonna try jumping it again with the new battery right now, so if anyone is online and out there with any suggestions, i'm all ears...thanks a million
:angry:
:angry:
