The Saab Link Forums - View Single Post - How to T5 a c900, the easy way
Old 11-30-2012, 11:21 AM   #541
mike d
mike d's Avatar
here is a very minor update for all you T5c900 guys. Last night i built a harness to be obd2 compatable, because the installer has access to lots of scan tool, and no canusb. This will help him during first start-up to see his RPM signal, and sort out any initial sensor issues
So here is what you need to know if you want an obd2 port in your c900!
OBD2 pin#..............Where it goes
7 ......................... ECU pin 33
14 ........................ECU pin 56
4 & 5......................... Ground
16 .........................+ 12 power
MikeDTuning.com
mike d is offline   Reply With Quote
