The Saab Link Forums - View Single Post - November 2012 Saab Of The Month
Old 11-09-2012, 05:12 PM   #1
grkguy89
Greek Mod
grkguy89's Avatar
YLLWJET
un named yellow swedish car (2000 Viggen)
ENGINE INTERNALS
block- line bored, decked, cylinders bored to 91mm
engine balancing
crankshaft straightened
wossner 91mm pistons
pauter 4340 chrome moly rods with arp bolts
calico coated bearings
modified t5 timing cover housing/oil pump
custom t5/t7 hybrid head. 3 angle valve job-t5 valves lapped w/ trollspeed 160# springs and enem 276/10.4 cams t7 lifters
modified adjustable cam gears
arp head studs
T7 multilayer headgasket
9.2:1 compression ratio
FUEL/RANDOM MODS
JZW custom tune
a/c delete
9-5 power steering pump w/ ss lines
maptun silicone radiator hoses
aeromotive 340 fuel pump
siemens 630cc injectors
ngk bcr8es copper plugs
B&M oil cooler w/ dual 4' spal fans
modified oil filter housing
royal purple hpr 15w40
TURBO SETUP
garrett gtx3071R w/ tial 0.63 A/R v-band exhaust housing
tial mvr 44mm external wastegate .8bar spring
tial mqr diverter valve
custom intercooler 24x12x3
custom 2.25 stainless steel intercooler plumbing
custom 3' aluminum cold air intake
GS modified turbo manifold and downpipe
GS 3' exhaust
SUSPENSION/STEERING/MOUNTING
18x7.5 BBS RK1 wheels BLACK PEARL
225/40/18 hankook ventus v12 tires
gs custom front coilover kit w/ koni race dampers and eibach springs
gs solid front upper strut mounts
gs rear race eibach springs
selholm racing control arms w/ heim joints
gs 22mm rear sway bar
gs race engine mounts
gs steering rack brace
gs rear axle poly bushings
gs poly steering rod bushings
gs rear hatch brace
BRAKES
stainless steel brake and clutch lines
front 308mm slotted/vented discs w/ hawk hps pads
rear 9-5 aero 300mm slotted/vented discs w/ hawk hps pads
super blue DOT4 brake fluid
DRIVETRAIN
gs solid race mount
gs short throw shifter
spec 3+ clutch
quaife lsd
saab 4.45 final drive
royal purple syncromax
ss clutch line
INTERIOR
JL AUDIO component speakers front
JL AUDIO 6x9 speakers rear
JL AUDIO 10' subwoofer and amp
Alpine headunit
innovate motorsports a/f gauge
aem boost gauge
aem fuel pressure gauge
aem oil pressure gauge
aem oil temp gauge
aem volt gauge
POWER OUTPUT
455whp 437ft/lbs
Current Activity: Moderating
grkguy89 is offline   Reply With Quote
