The Saab Link Forums - View Single Post - Spec flywheel
Thread: Spec flywheel
Old 07-26-2012, 07:06 PM   #6
Drew in Houston
Drew in Houston's Avatar
I like mine. Have probably 120k miles on it in a B205R and now a B235R. I've always used stock bolts. If your car's tuned right and you know how to drive a manual transmission it's not an issue to drive at all. It does make the car more diffifult for a beginner to learn-on, if you ever try to teach someone how to drive a manual.
When I sent my rotating assembly out for balance I was surprised how much they had to grind off of this supposed "performance" part to balance it. Overall I'm totally less than impressed with every single SPEC item I've purchased and will try to avoid them in the future if there's any type of alternative.
Drew in Houston is offline   Reply With Quote
