The Saab Link Forums - View Single Post - are all 9-5 blocks the same ???
Old 04-11-2012, 10:21 AM   #3
pete93t
pete93t's Avatar
Send a message via AIM to pete93t Send a message via Yahoo to pete93t
Yeah the only thing I was worried about is the oil pan difference and if the newer oil pans from the newer 9-5s will bolt up to the 2000 block. I relized after I tore it apart that the oil pan on the 2000 motor bolts onto the lower part of the transmission and also acts as a flywheel cover as well were as the newer oil pans like my 04 end near the flywheel and there is a small plate to cover the lower end of the flywheel I believe there 10mm bolts. Sobibwasnt sure if the blocks were the same
-05 9-5 aero (BOOST2)-
-1980 900 Holset t5 monster-
pete93t is offline   Reply With Quote
