are all 9-5 blocks the same ???
i just pulled the motor from my 2000 9-5 aero 5spd. and was wondering if the block would work on a 03 9-5 aero. the only dif i could tell was the oil pan on the 2000 is dif from the 03 and the plate that attaches to the block on the flywheel side looks dif. i was going to reuse the transmission for my 04 but the bell housing looks dif which is no big deal i can sell the trans but my main Q is the block. i need to be sure it will work ok on the 03
my plan is to take the block from the 2000 aero and use the top end off the 03 and the transmission from the 03 which happens to be a automatic
-05 9-5 aero (BOOST2)-
-1980 900 Holset t5 monster-
