The Saab Link Forums - View Single Post - If you haven't cleaned your IAC....
Old 02-15-2006, 09:16 AM   #4
BurnsSide42
BurnsSide42's Avatar
Use foaming engine degreaser - followed by rinse with HOT water (will evaporate most of the water after on it's own) and shake dry. (or blow out with compressed air) This is how I've done this everytime with success every time. Well worth the 10 minutes it takes.
Check out
for your repair needs
BurnsSide42 is offline   Reply With Quote
