The Saab Link Forums - View Single Post - DIY Clutch replacement
Old 11-13-2011, 10:18 AM   #11
pitman
pitman's Avatar
if your removing the trans fill your own trans mount with polyurethane. its messy and takes time but you can do it if you can do a trans swap. you can fill the front mount too. i have pics of mounts i filled if you want them pm me. i can sell you a filled one i have already filled for $30 but shipping might kill it. plus if mine is too stiff you can drill out some material to soften it up. and just to let you know your car is going to shake like craazy if you do all the mounts. fine for a race car but not as good for street/daily. i did the trans mount and i can feel it a bit on start up and idle
also check out arp bolts for the flywheel
and i i like the cable clutch better than hydro. simple is better
pitman is offline   Reply With Quote
