The Saab Link Forums - View Single Post - DIY Clutch replacement
Old 11-12-2011, 09:12 PM   #7
srp
srp's Avatar
Send a message via AIM to srp
First time I did my clutch, I took the intermediate shaft off.
Second time, I left it on.
Either way, two people are helpful.
If you have that much free time, you should swap to the hydraulic setup as well.
Might as well do the rear main seal while your there.
Don't forget new flywheel bolts if you remove the flywheel.
Also, don't forget new pressure plate bolts and axle nuts.
srp is offline   Reply With Quote
