The Saab Link Forums - View Single Post - Strange Oil Leak
Old 10-31-2011, 09:27 AM   #9
SPG-GASM
SPG-GASM's Avatar
STOP! You're problem is too much pressure in the crank case. Check you're Pcv valve for correction operation. The biggest problem with this oil leak has been caused by the brake booster diaphragm leaking, also causing excess pressure in the crank case.
SPG-GASM is offline   Reply With Quote
