The Saab Link Forums - View Single Post - 01 9-5 3.0 another coolant temp sensor problem?
Old 09-28-2011, 10:36 AM   #6
jssaab
jssaab's Avatar
All wrong for a T7 car, Its the T-stat, If T7 senses that the temp is not going to operating temp ( too low) in the required amount of time, it drops the Temp gauge to zero, kinda as a visual its not up to temp indicator ( there is no light) Did you notice the temp not quite making it to the 9 o'clock position prior to this?, it woudl indicate a failing T-stat...
that said for the V6 if you are in there do them both its not worth the hassle of dong one then tearing it al down to do the other...
jssaab is offline   Reply With Quote
