The Saab Link Forums - View Single Post - 9-5og uprated pressure plate needed
Old 09-20-2011, 06:06 AM   #1
av_dumitrascu
Well, as I have already told you on thread, my pressure plate on my project car (9-3og/Viggen Stage6 with F40 6 speeds gear box) is sliping from the 4th gear and above (mind you I have 6 speeds) from 3.000 RPM up
This, after I played a little with the various rate springs from the Forge diverter valve. Started from green, then red, now yellow, and I cannot express how much Boost the turbo is building....thus resulting in clutch slip
Bottom line, I need an uprated 9-5og pressure plate, to hold up to 600 Nm. Specifically 9-5og, since I am using a hybrid clutch...
thought to post this also here, since there are some guys around with high powered 9-5og cars
Thanks for recommendations!
join me: Lucian Dumitrascu | Facebook
join me:
av_dumitrascu is offline   Reply With Quote
