The Saab Link Forums - View Single Post - Innovate LC-1 Users: Help!
Old 09-18-2011, 02:12 PM   #1
Cm452
I was curious as to whether after bench calibrating both the wide band processor and the sensor whether or not I'd have to do it again once i transplanted to the car. I'd think not because the manual calls for a switched 12v source, but I'd rather know for sure before I wire everything up.
While I'm at, since ecu project is down I'll ask here; once everything is in place, how did you get T5 suite and the Lc-1 to communicate and agree with each other? I know you select the 69th pin input and how to work the realtime panel. I just remember reading that certain values had to be entered in to configure the two so it didn't read artificially rich or lean.
Thanks,
Cm
Cm452 is offline   Reply With Quote
