The Saab Link Forums - View Single Post - 01 9-5 3.0 another coolant temp sensor problem?
Old 07-08-2011, 05:28 AM   #3
BurnsSide42
BurnsSide42's Avatar
Also good idea to replace the t-stat and flush the cooling system (if you didn't when you replaced the heater by-pass valve) with the coolant temp sensor. Then you will be all set for several years - pending your hoses are intact and healthy.
Check out
for your repair needs
BurnsSide42 is offline   Reply With Quote
