The Saab Link Forums - View Single Post - WGA spring upgrade
Old 04-17-2011, 01:32 PM   #5
vayrix
Originally Posted by byastremski View Post
you can also just run a helper spring externally to help up your base boost... just go to advanced and get a spring pack... try a couple different ones... make a little metal bracket and attach to where the wastegate bolts up to the housing and run the spring to the swing arm of the turbo... much easier way to do it...
Yes, I've done that already when I thought that only my actuator is a problem. I have "custom" made spring by me
So there is no difference between putting it outside, or putting it inside?
vayrix is offline   Reply With Quote
