The Saab Link Forums - View Single Post - T5 Plug & Play Conversion
Old 02-09-2010, 08:25 AM   #16
white9ktalladega
ok i have t5 out of a 1996 9000 cse installed in my 91 9000 my trionic box is from a 96 cs. my car runs but i need to know who is experiencing what with the crank sensor wheel i have mine on the crank pully and set on the 20th slot.my car was missfireing a lot and i went through alot of diag and came down to timing issue so i unbolted the bracket for the sensor while the car was running and moved it down about 2-3 slots car started running alot better.. so my question is what slot should the sensor be on with the engine at TDC and my second question is does trionic 5.2 and 5.5 have different settings for where the sensor is
thanks in advace guys
white9ktalladega is offline   Reply With Quote
