The Saab Link Forums - View Single Post - E-85 fuel is awesome!!!
Old 08-29-2009, 05:41 PM   #4
Vigge
With E85 you need to run more timing since you dump alot more fuel into the cylinder and if you dont the benfit will be negative.
Anyhow just a reference I run 14deg timing with 34psi with norml gas
Key more me is to have the engine working 110% with normal fuel and then E85 if needed, but use it as band-aid to cure/hide problems is a no-go.
Vigge is offline   Reply With Quote
