The Saab Link Forums - View Single Post - T5 ecu question
Thread: T5 ecu question
Old 08-18-2009, 06:51 AM   #8
8valvegrowl
8valvegrowl's Avatar
It will be fine. The stock manual maps are no more aggressive than say a stage 1-2 auto map. The boxes have both maps on there, it's just a firmware setting. The car may even adapt to the gearbox type, someone with more auto experience could chime in....I've only dealt with manuals. Just go easy on your slushbox.
If you want to put an auto ECU into a manual, that will work fine too...it will just have a little less boost in all gears.
8valvegrowl is offline   Reply With Quote
