The Saab Link Forums - View Single Post - Boost controller and B.O.V?
Old 08-12-2009, 08:48 AM   #6
dan-the-kid
dan-the-kid's Avatar
Its a similar reason for the MBC.
Since the car uses a BPC(boost pressure controller), like a mbc but controlled by the ECU. If the ECU is telling the BPC to allow an X amount of boost pressure, but you have your MBC set to some other amount, the engine management (T7) is getting different MAP readings while thinking the boost pressure is set by the BPC, when its not.
In layman terms....
T7=HAL9000.
dan-the-kid is offline   Reply With Quote
