The Saab Link Forums - View Single Post - New wheels
Thread: New wheels
Old 04-08-2009, 05:15 PM   #9
tophusmaximus
tophusmaximus's Avatar
Originally Posted by AutoXer01 View Post
yes they are a different bolt pattern, but they do make 5x112 17's but in an odd offset or something I have to double check that. The price I got quoted from tirerack when I called was 473 each...not bad considering what they are. I'm sure I could just get an adapter made for the correct bolt pattern??
wobble bolts would work fine. but the hubs are different, and you cant go from big(saab) to small(vw/audi) thru an adapter, at least i dont think you can(someone correct em if im wrong).
meaning youd have to bore them by a guy in a machine shop.
itd be a lot of work, id keep looking for something for a volvo, cause they have a 5x108 pattern adn jsut wobble bolts are needed i believe.
none of you can talk/function with dicks in your mouths.
Amateurs.
2000 9tree
tophusmaximus is offline   Reply With Quote
