The Saab Link Forums - View Single Post - T5Suite Hardware and Software for WASSAAB?
Old 09-05-2008, 04:08 PM   #15
LarryM
LarryM's Avatar
Not the infamous item made by BF Chuck ( still waiting on mine ........) It's a type of connector with male pins on both ends - one side is soldered to a pad on the circuit board. the other end is used to connect to a cable ( for our purpose, the BDM connector).
If you've ever swapped out boards on a computer, and had to unplug connectors - the section of the connector with the pins staring up at you is the header.
LarryM is offline   Reply With Quote
