The Saab Link Forums - View Single Post - Clocking at 9000 turbo for a 9-3
Old 07-29-2008, 06:18 AM   #2
NahumCC
NahumCC's Avatar
I'll make this really easy for you.
Remove your viggen td04. Remove the wastgate, unbolt the vband clip on the viggen turbo that holds the turbine housing to the center section. Do the same on the 9000 td04. Remove both housings. You may or may not have to remove the locating pin, just depends on how everything lines up clocking wise. Install the 9000 turbine housing onto the viggen td04. Make sure the orientation is where it should be. Install v-band and re-install the turbo.
2013 FR-S
NahumCC is offline   Reply With Quote
