The Saab Link Forums - View Single Post - Ng 900 nordic race car
Old 05-31-2008, 12:02 PM   #13
JZW
Originally Posted by Tweek's Turbos View Post
Yes, I'm quite aware, however the quote was shafts, not chains. As in no balance shafts, I have my own build going on, and one of the engine blocks had a knackerd up shaft sprocket on one side. I sill have the other engine, but want to review options here.
Ok, sorry, I was not sure if you knew the difference You are right and if you remove the shafts themselves, there is nothing to block the oil passeges and keep the oil pressure up.
Nick made some aluminum inserts, but the only advantage would weight and I personally don't think its worth the time and money and effort to save the 6-8 lbs or whatever they are...
John
JZW is offline   Reply With Quote
