The Saab Link Forums - View Single Post - My new Autometer GS Series Gauges
Old 05-30-2008, 01:25 PM   #19
perkj
perkj's Avatar
To further clarify, the zSeries have the "around the dial" lighting which means the green light is shined on the outside of the dial and then the light is reflexed off the numbers where as the GS Series has "thru the dial" lighting which the green light shines from behind through the numbers.
So when I say the GS Series is more Factory like is because the stock gauge panel is "thru the dial lighting", where as say in my old VWs the "around the dial" was the better match
...its an attention to detail thing
2000 Viggen
x-VWer:
perkj is offline   Reply With Quote
