havin more pistons will inprove your braking greatly and the pressure used to step on the peddle will be less becouse you have more pistons applying force also you want to be carefull becouse the diffent volume for fluid and the pistons you may need a larger reservor and it can make diffences in the brake booster but if its desined for the car though go ahead
