The Saab Link Forums - View Single Post - Possible Air Sensor Switch to Turbo Version
Old 04-11-2005, 01:34 PM   #2
ng900
ng900's Avatar
Send a message via AIM to ng900
I don't know if that'll work, but I can tell you from messing around with the AMM when doing my intake, and later when putting in the supercharger, that thing is a PICKY little sucker. Even the slightest problem with the reading will make your car start stuttering like crazy, and stall when you try to accelerate sometimes. So if you try it, make sure you still have the oem one to put back on.
I just want to add, there are a lot of people on eBay I noticed advertising a "chip" or resistor for the intake sensor that will supposedly give you 20hp increase. THIS WILL NOT WORK ON SAABS. That will only work on cars with a 2-wire plug, such as mostly American cars. Saabs have 4-wire plugs. I tried the resistor, I tried every wire combination, it doesn't work, the car stutters, and the check engine light comes on. It sounds like a great thing, and on some cars it might work, but not for Saabs.
Ethan J. Carnes
ng900 on cardomain.com
exdrivers = team on cardomain.com
1995 ng900s 2.3 N/A w/ mods
ng900 is offline   Reply With Quote
