The Saab Link Forums - View Single Post - Tutorial: Removing Mesh from Air Sensor
Old 04-08-2005, 10:21 AM   #1
rcmdesign
rcmdesign's Avatar
Ok so I decided to remove the mesh inside the air intake sensor. I believe it does slow down air to a point, and every little bit counts. So I first used a pair of pliers to rip it apart, and then I realized that I could of just slipped the mesh right off! It's only held on by two clips sort of. See pics below. So you don't have to destroy it like I did, you can keep it in case for some reason you want to slide it back on. You will see what I mean by the photos below.
Before
After
Slots inside to quickly remove the mesh
Finally the remains
Rob
Swedish Performance
rcmdesign is offline   Reply With Quote
