The Saab Link Forums - View Single Post - supercharger?
Thread: supercharger?
Old 04-06-2005, 09:32 AM   #13
rcmdesign
rcmdesign's Avatar
"IT HAS A COMPUTER DESIGNED INNER STATIONARY BLADE WHICH AS THE AIR FLOWS OVER IT CREATES A SWIRLING EFFECT THUS INCREASING THE AIR FUEL MIXTURE AND CREATES A FAST BURN EFFECT IN THE COMBUSTION CHAMBER"
It does both, produces a swirling effect and compresses...
"THIS CHARGER IS POWERED BY A 24,000RPM MOTOR(18,000RPM UNDER LOAD) AND PRODUCES MORE CFM THAN MOST ANY OTHER BUT THATS NOT ALL"
Originally Posted by driver found
That unit is designed to compress air, not swirl it.
And don't bother trying it, they're worthless unless you've got an engine with really tiny displacement.
And my question is, have you ever tried this or seen numbers for it? Where are you getting that it doesn't work unless you have "tiny" displacement?
Rob
Swedish Performance
rcmdesign is offline   Reply With Quote
