The Saab Link Forums - View Single Post - Cel Blink Code??
Old 05-12-2007, 03:19 PM   #7
Newf9000
Newf9000's Avatar
From saab9000.com....
Procedure (DI/APC)
To obtain a fault code reading:
1. Turn the ignition switch to the Drive position without starting the engine.
2. In about two seconds the CHECK ENGINE light will go out for about 2 seconds. It will then begin flashing the fault code.
Fault codes (DI/APC)
Fault code/ Fault
2 Internal memory check failed
3 Watchdog (control module fault).
May also be caused by a defective spark plug or ignition module.
4 Knock sensor
5 Engine load signal from LH or MAP sensor incorrect
Newf9000 is offline   Reply With Quote
