Good News (hopefully).. The fuel pump isn't bad. I couldn't get it to run using normal means, but I was also not getting any power at the plug going to the pump. I jumped 12 volts to the pump and it started immediately and within a second or so, I could hear that it had built pressure.
I checked the relays and replaced them with some spared I had and that didn't fix the issue either. Something is still not turning the pump on..
Then I remembered the old red 1991 9k that I had had a bad CPS and that had the same issue where we couldn't get the fuel pump to run.. With that in mind, I cranked it for a few seconds and watched the tach hoping to see it bounce.. Nothing.
So a bum tachometer while cranking would point to a bad CPS, correct?
The next problem is that the only thing I can find is this splice in kit from eeuroparts.com..
https://www.eeuroparts.com/Parts/549...lice-7484546K/
Is this really the only option?
