The Saab Link Forums - View Single Post - T7 to t5 pcv system
Old 02-17-2018, 09:57 AM   #4
Jeffcentola
Originally Posted by jpgroth View Post
Check out Stephen's build.
https://www.saablink.net/forum/perfor...-9-3/81194.htm
He also has one over on the other Saab forum, same build. I'm not sure he mentions what he did. I'm also building a 234 for my viggen with same intake manifold steup as Stephen. I haven't gotten anywhere near to thinking about PCV, but I was under the assumption I'd just run the t7 set up or as much of it as I can.
What made you decide to put a b234 in your viggen? My block needs to be bored out in my 02 se, im thinking now rather than use a b234 that id have to swap out timing cover oil pan etc and probably hone, I might just send the block out to be machined. What happened to your viggen?
Sent from my LGMS210 using Tapatalk
Jeffcentola is offline   Reply With Quote
