The Saab Link Forums - View Single Post - 2004 saab 9-5 combi won't crank
Old 01-26-2018, 12:18 PM   #3
Stiiiiiv
Thank you for your prompt reply.
There were no new messages from the SID display on the dash, just an old reminder that the windshield washer fluid was low. I did plug the trim ring back in, but I'll recheck it when I continue this adventure tomorrow morning. Is it likely the ring could have been damaged when I removed it and then reassembled the center console? Are they very sensitive? If it's bad can it just be replaced or does it need to be coded for my key?
I'll check the voltage at the places you suggest as well tomorrow and post the results.
Thanks again for your helpful advice.
Steve
Stiiiiiv is offline   Reply With Quote
