The Saab Link Forums - View Single Post - Fuel gauge problems
Old 08-16-2017, 06:07 PM   #2
adidas_007
adidas_007's Avatar
yes yes & yes, you can make a removal tool. I made one from a piece of pvc that was the same size and notched it to match the black ring. if you internet it you'll find repair guides. Fuel Pump Replacement - Step 1
What I did was remove the fuse for the fuel pump, then run the engine till it stops, to get as much fuel out of the system as possible.
I don't if there is a fix for the fuel sending level, but you can fix/ upgrade the fuel pump cylinder its self with a new fuel pump.
2010 9-5 Aero
2004 9-5 Aero 5pd Stg 3 Wagon, 1 of 18 Made
1990 900 Convertible
2007 Cbr600
adidas_007 is offline   Reply With Quote
