The Saab Link Forums - View Single Post - Steering Rack Brace
Old 08-15-2017, 05:00 PM   #2
Trionic3000
Drew In Houston
I don't remember exactly how things are there on that mount, but I think you're talking about a spot welded stud that's sticking out? I guess you'll have to either break it off the whole way, drill a hole, and use a through-bolt and nut; or weld something back on. Do you have a TIG welder? Or, do you have a picture of what you're talking about?
If you have a TIG welder it's a 10 minute job to weld something back on there, if it's the way I'm remembering, otherwise.. Where are you located?
edit: I can't find a line art picture, but it looks like WIS only calls for 18 ft-lb on those bolts
Trionic3000 is offline   Reply With Quote
