The Saab Link Forums - View Single Post - 2000 Saab 9-3 Viggen
Old 05-07-2017, 05:29 AM   #8
Trionic3000
Drew In Houston
The GT3076 is a good turbo, but beyond the air inlet piping, something else to consider is the steel oil and coolant lines vs flexible braided hoses.
I haven't found any flexible braided lines that don't wear out over time and use--that's a high heat area. You can insulate flex lines to extend their life, that slows things down, or swap them at some time interval before they fail, but left alone flexible tubing will get hard and crack eventually.
People run adapters with flexible lines all the time, they're not like instant death or anything, but compared to the factory steel lines that don't really wear out for the life of the car, you're adding unreliability and new higher wear/failure items if you go the flex line route.
Trionic3000 is offline   Reply With Quote
