The Saab Link Forums - View Single Post - 2000 Saab 9-3 Viggen
Old 05-01-2017, 01:30 PM   #3
Elyk
Elyk's Avatar
Originally Posted by Jameson View Post
400 crank or 400whp? Pump gas 93, E85 or both?
400wheel, e85 or pump. I am currently running a 255lb Racetronix fuel pump and have access to e85 less than a mile away. I run a somewhat 70/30 mix. I've played around with a full tank of e85 but the purity levels seem inconsistent and altitude for me is a major factor.
I should also state the current engine mods:
B235 Engine
Maptun Stage 3 BioPower (e85) tune (91+)
630cc Siemens Injectors
255lb Racetronix Fuel Pump
PLX Gauge OBD2 Touch (AFR & EGT Sensor Modules On The Way For Remote Tuning)
VDO Voltage Gauge
VDO Vacuum Gauge
3" Maptun Downpipe & Flex Pipe
Remus/ Saab Resonator Tip
do88 Crossflow Front Mount Intercooler
do88 Aluminum Charge Pipe
do88 Intake Relocation
do88 Heater Core Hoses
ITG Open Air Filter
Forge Recirculating Diverter Valve
PCV 6
Stock td04hl-15t
Elyk is offline   Reply With Quote
