The Saab Link Forums - View Single Post - Rough running after cylinder head overhaul
Old 10-31-2016, 05:49 PM   #2
Trionic3000
Drew In Houston
The clatter is because the hydraulic lifters aren't pumped up yet, sometimes that can take 5 minutes or so for the oil to get warm enough and it'll go away. It might be off a tooth on timing too, can't really tell.
Trionic3000 is offline   Reply With Quote
