The Saab Link Forums - View Single Post - 1999 Saab 9-3 HX35 SWAP?
Old 09-04-2016, 12:28 PM   #8
Trionic3000
Drew In Houston
I like the Bosch 044's. They're huge but they'll fit in the stock canister and that way you know you'll never run out of pump.
There are two injectors that are pretty common for larger setups, Siemens Deka 630's, which will be too small for an HX35 IMO, and the 850's, which are harder to tune and make run right--but do have published latency tables available to calibrate correctly.
I don't know if BCB does the Deka 850's or what, but if they're your chosen tuner I'd talk to them and ask them what's their preferred big injector that they can make idle correctly and behave during transitional off/on throttle situations and not wash down your cylinder walls and ruin your oil---especially if you ever think about running e85.
Trionic3000 is offline   Reply With Quote
