The Saab Link Forums - View Single Post - 1999 Saab 9-3 HX35 SWAP?
Old 09-04-2016, 10:22 AM   #6
Trionic3000
Drew In Houston
Here's a calculator that helps you size injectors: https://www.rceng.com/technical.aspx but if you're familiar with sizing injectors for V8's then of course the approach is pretty much the same so that's probably old news to you.
Every question that you've asked has been discussed here very thoroughly through the years.
Additionally, a large portion of what constitutes standard staged tunes these days was developed on this very site, so there's lots of expertise here that can respond to specific and knowledgeably formed questions.
As example, you ask "what intercooler do I need", the answer to that is actually "a bigger one".
Beyond that, if you do some searching and ask something like "is ebay cooler xyz really worse than the $400 Genuine Saab unit?" or something like that, you're likely to get a few more bites.
Welcome to the site by the way, there's a ton of good information here.
Trionic3000 is offline   Reply With Quote
