The Saab Link Forums - View Single Post - hood release latch rubbing on A/C condenser
Old 06-08-2016, 05:53 AM   #1
abdukted1456
Trollerator
abdukted1456's Avatar
yup, got a pinhole in my condenser, was going to replace and I noticed that right at that spot it is very worn away and the hood release latch seems to be resting and rubbing against the condenser. It probably wore through and made this hole! so the question is, can the release/latch position be adjusted or is it more likely the condenser was not mounted correctly?
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline   Reply With Quote
