Actually. This is a long shot because it would have to be really bad to cause a massive leak, but I'm going to throw down a guess that it's related to the fuel pump replacement, and whoever did the work messed up the o-ring gasket that seals the top of the fuel pump canister to the tank. It's pretty easy to mess it up. If you fill the tank up the entire way do you smell fuel? Pull up the back seat and remove the access cover, is it wet on the top?
Co-Founder: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. First T7 19T turbo setup. First T7 Deka 80lb. injector setup.
