The Saab Link Forums - View Single Post - SAAB Savior -> GenuineSAAB short shifter, No reverse :-/
Old 03-14-2016, 08:40 AM   #13
AeroJ
AeroJ's Avatar
Still ongoing believe it or not.
I'm waiting on a used linkage (part with the ball and sockets) that should be in tomorrow. I removed the linkage that was on the car, and although I understand how it is attached and how it works 10x better now, I still can't really tell if there is enough wear to cause my issue. The rubber bushing is a slightly worn, but nothing to cause this IMO. The clamp was stuck in one of the slots, which could be an contributing factor, but we will see when I throw the new linkage in.
The socket joints were improved on the 2004+ and are metal now. I think this is a major area of improvement from the plastic ones with the clips that tend to pop off. I saw a post where a guy ordered stainless steel sockets and threaded rods from McMaster-Carr to update, which I am very much considering doing, especially since they are cheap!
'j006' on SC!
AeroJ is offline   Reply With Quote
