The Saab Link Forums - View Single Post - Airbag light warning after replacing front seats
Old 06-03-2015, 08:39 AM   #2
DrewP
DrewP's Avatar
If the only problem was that you powered the car on while the airbag connector was unplugged, then it will have to be reset with a Tech2 at a shop that can work on cars. The fault code is set in the SRS module, and the only way to re-set it after fixing a fault is with a Tech2.
If one of the seat mounted airbags is bad, the light will come back on, and there will be a code set for which airbag is faulty or disconnected.
DrewP is offline   Reply With Quote
