The Saab Link Forums - View Single Post - manual tranny reverse synchronizer?
Old 03-31-2015, 08:48 AM   #3
Drew in Houston
Drew in Houston's Avatar
Can you start it in reverse and the clutch pedal pressed in - and back up like normal - then press the clutch in and knock it out of reverse? If you can't do that, I'd check shifter alignment, and if it's not that, seems like there may be larger issues.
Drew in Houston is offline   Reply With Quote
