The Saab Link Forums - View Single Post - Transmission Banging!
Old 02-17-2015, 03:07 AM   #2
Mike Brennan
2002's had valve body problems. They can be changed out w/o removing the transmission. However, the 1st stem is to do a 3x drain and fill with the right transmission fluid. the 02's began with the use of Mobil 3309 or Toyota Type IV I believe. Do not put in the wrong fluid. Of course I am assuming you have checked your motor mounts and they are all ok.
Mike Brennan is offline   Reply With Quote
