The Saab Link Forums - View Single Post - Broken Tensioner Problem Solved
Old 12-17-2014, 05:21 AM   #3
Saabeh
Wagon Shaggin'
Saabeh's Avatar
Originally Posted by seano44b View Post
I imagine that this happens quite a bit. You are replacing the serpentine belt and the tensioner bracket cracks, so that you are not able to get the pry bar to move the tensioner. I got around that problem and the possible added expense of having to replace the tensioner. I used a carjack from an 89 Mercedes Benz. By placing the jack foot or base on the firewall of the SAAB and positioning the jack just behind the tensioner bracket, you can slowly wind the jack and move the tensioner. TA DA, the belt slid right over the tensioner pulley and what looked like a daunting repair job and additional money being thrown away, turned out to be a success.
Hope this helps those with similar issues.
Sean O.
Back yard ingenuity, I like it!
Originally Posted by Drew in Houston View Post
Another way is to use a pipe wrench around the back of the assembly and pull forward like normal.
...it's better not to push the wrong way and break it though in the first place
We have all learned the hard way at some point.
Saabeh is offline   Reply With Quote
